It is currently Sun Aug 24, 2025 4:21 am
PostPosted: Thu Jul 11, 2013 11:40 am
It looks like a booby sticking through the soundhole. A green booby. laughing6-hehe
jw ( o)===:::
PostPosted: Thu Jul 11, 2013 12:31 pm
First name: Aaron
Last Name: Craig
State: Missouri
Balloons for me as well. works well for covering sound ports too (two balloons - use the sound hole balloon to hold a smaller balloon in place to cover the sound port). You'd think there may be an issues with getting lacquer in the right spots on the edge of the sound hole, but lacquer seems to flow well into the lip. I'm not looking for much finish in that area anyway (no real need to level or wet sand around the lip if you have thin coats and avoid drips).
Aaron Craig
PostPosted: Thu Jul 11, 2013 12:38 pm
First name: Aaron
Last Name: Craig
State: Missouri
Mike_P wrote:
Rob Flindall wrote:
you can measure the dry thickness by taking out the balloon and flaking off the finish and measuring it's thickness.
unless you do no between coats sanding this method will give a false result...the measured thickness on the balloon is going to be more than what is actually on the top
It's true that using this method you can't accurately predict how much finish you've sanded off. But, if you use one balloon for spraying your initial build coats, after you finish you'll have a pretty accurate measure of what's available to sand off. Use another balloon for your top coats, . . . same deal. You could do the same by spraying a sheet of glass once every coat and using a mill gauge, but I like being able to peal off the finish film and measure with a micrometer or dial indicator.
Aaron Craig
PostPosted: Thu Jul 11, 2013 6:30 pm
I always keep three different colours of balloons. I choose the colour depending on whether I want more treble, more base or more mids.
Brent
Oh, and here in Canada it's 'towes'- google Vic Towes.
PostPosted: Thu Jul 11, 2013 6:45 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Brent
oops_sign You switched the w and e, Brent. Should read Toews, but pronounced "Taves". Go figure. [uncle] I don't mean to be nitpicky, but this is a tough forum. laughing6-hehe
Alex
PostPosted: Fri Jul 12, 2013 7:56 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, orange will work in a pinch.
